4 subs one amp???
corteznewbie
i'm going to be running 4 4 ohm dvc subs. is there any other amp other than audiopipe i could run. looking for at least 3000rms
Team DBs (Driven By sound)
sonic electronix has refurb hF XX colossus II (~3000wrms @ 2 ohm) for sale for $450
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
There are about 20 amps that I can think of off the top of my head that do 3k+ on 1 ohm.
American Bass VFL 500.1, Atomic 7k, Cactus, soundigital, sundown, etc.....
How much you wanna pay is the better question.
The final load will be 2 ohm.. So 3k @ 2 ohm
@ cortez
I run 1/0 to mine, works fine. As for warranty, not sure. Sonic may have a 1 year warranty on it, or you may have to pay some $40 charge to a 3rd party for lifetime warranty on it.
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
Ummm....4 - 4 ohm subs wired in parallel = a 1 ohm load. If they are done series/parallel then they are a 4 ohm load.
How are you getting a 2 ohm load?
the subs are dvc not svc
dd is a good amp Dat,sundown, all do .5 daily
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 578 Guests (See full list)
