question about classes
Jayrapboy...usually the fuse under the hood isn't counted. There has to be a fuse within 18 in. Of the amp or they use the fuses on the amp
Okay so even tho i dont need it. I could add like a 10-20 amp fuse within the 18 at the back...
thats what i was thinkin.
Depends on if your amp has fuses on it. I have 4 30amp fuses on my amp...if I was to put an inline fuse before the amp...they still use the fuses on the amp to determine class. Bigger amps usually don't have fuses so you have to use inline. So if your doesn't have fuses, you can do that. Just be prepared to change fuses if your going to be using that small of fuse.
www.dcsoundlab.comDCforum.jpgyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3
SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO
on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator :)
Well my RF has to 40 amp fuses in it... So i couldnt do that...
Oh i know a guy at the comp yesterday was able to get 90 amps of power through 5 amp fuses... said he was able to get a 3 second burp out..
But i am all about music.
Was it in a crx?
More than likely it was Joe Ault...9 time world champion. I've seen him do 150+ with those 5amp fuses
