ok i recently got a vertical door kit but the shocks didnt come with it....as i said in earlier posts i have a 1988 honda crx.... would an air cylinder work if i put one in the place of the gas shock absorber? im finding it hard to find a gas shock aborber for the hindges i got..... cause as right now i was just going to see if i could use the hindges without the gas shcoks.... so basically id have to hold the door up when i get in and hold it and when i lowered it id have to be careful and let it down slow..... can anyone help me?
true.....even at low air pressure levels if you hit that switch it would probably be WAY to fast.
Follow my Tweet (Twitter)
  • 4 weeks later...
You could run smaller line (down to 1/8") to make it slower, but the main problem would be finding room for the air cylinder!  Those gas struts that come with the lambo kits have a lot of pressure in them to lift that door.  An air cylinder with a 1" bore would be easy to mount, but I don't know if it would be strong enough at 150 psi to lift the door properly.  And going bigger on the cylinder diameter will probably give you clearance issues...
I think a linear actuator would be a smarter, more efficient way to go.  Good luck either way!
-Phil at FBI
  • Who's Online   0 Members, 0 Anonymous, 1747 Guests (See full list)
