Need a box designed!
Height 18"
Width 37"
Depth 29"
Trying to see if I can fit the DC Audio XL 18 in my trunk. Not sure if it will fit..if it doesn't im just going to get the xl 15. If anyone can help me out that would be awesome!
Thanks!
What kind of tuning are u looking for
2 18's Fi SSD All Options Dual 2 ohm
Rockford Fosgate T20001 Bd
1/0 gauge Knukonceptz power wire
Pioneer Touch Screen Navigation AVIC F700
13.62 cu ft box ..28 hz
250 amp alternator
2 kinetik 2000 batteries
Xs Vcm Module
Whatever sounds the best? I see a lot of ppl do around 30-32hz
it depends on what your vehicle peaks at......since ur doing one sub i would go with 34-36 hz.....i can make a design
250 amp alternator
Xs Vcm Module
Height 18"
Width 37"
Depth 29"
I think your max dimensions may be a little bit too big!!
I dont think a 10 cubic foot box will fit thru your trunk opening, you may want to double check or build a cardboard box with your listed dimensions and test fit it.
Your only other option going that big is building the box inside the trunk and it can be a pita! :yahoo:
Awesome! I prolly should've mentioned that the 18" was to the top of my trunk.. so maybe tha 18 wont work.
No. Not at all. I personally think you be better of with a high end pair of 12s!
I built a few boxes for the cavs, and I dont recall exact measurements but Im pretty sure a box using your dimensions will not fit thru the trunk nor the back seat if they fold down or you remove them.
I built a single 18 box for my caddy trunk a long time ago and had to be built inside the trunk, with the sub firing up and port back.. only way the 18 would fit, and caddy has a way bigger trunk then a cav.
  • Who's Online   0 Members, 0 Anonymous, 887 Guests (See full list)
