2001 GMC Jimmy x2 18'' LVL 5 stetsom 7k2e 1ohm
Here it all begins
Please sub & follow this topic, Should have the new touch screen head unit in & the roof rack off by tomarow ! Will do a video update then.
-peace
P.S ANY and all sugestions are welcome.
2001 GMC Jimmy Car Radio Install Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
1998 Nissan 200sx
NOW:
Dex-p98r head
Planet Audio 300.4 mids and highs
Planet Audio/Pioneer tweeters/crossovers
Skar SK1500.1
3 SKAR Vvx15 dual 4 wired at .63
i can help ya broski
go out and get a wiring harness(walmart to have it same day) you follow the colors on the box of that wiring plug and connect them to to the clarions wiring harness....
make sure you connect all the wire specially if you have the bose system, i left one wire off that i usually never connect on the last cars i had and the deck would turn in the jimmy but no sound because the amp would not turn on=no sound :(
well once you get that harness you bought wired to the clarion connect the other end of the plug you just wired to the stock wiring plug that in the dash and IT SHOULD WORK
yes that yellow wire is the wire that turn the deck on! you will connect that to the yellow wire that is in the harness you buy
LINK: what the wiring harness you buy should look like
http://www.sonicelectronix.com/item_1520_Scosche+GM02B+-+GM02.html
hope it helps and its not too confusing
Thanks man that helps a ton ! Thease should come with the vehicles manueal.
looks good. is there a way of getting it to sit centered in the hole of the dash trim?
