the atomic lumina-2 atomic apxx 15s walled
updates- so after ripping everything out and wanting to do a diffferent thing i realized the vehicle was to rusty to really cut up and modify where i wanted
so i decided to throw everything back in and add some new things
so ripped out the amp/ wire
amp out
bus bars coming out
passenger seat out to re due the rcas
and now the building comes into play
started off with some flat bar i had layin around from old sign i "dumpster dove" for
and the garage
now back to installing everything got everything back in
grinding down paint to weld
and a teaser pic of whats to come
R.I.P!
(Nov-29-2009)
92 explorer
current build
drilling holes to tap them
working on buddys 300 installing deck- nav- sat radio and blue tooth 407552_10151249880190541_659335540_22856409_771709829_n.jpg
now back to the lumina
it was gettin cold so out came the heater
the deck mounting plate tab snapped so i made new one for it out metal
switched out the deck to an alpine
got the amp all mounted
and i got the deck all installed in the 300
heres a distance video to show how loud she is after adding the amp
only 1 set of powerbass 5.25" comps
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • 1 month later...
Updates
some coupling bolts welded up to some angle iron with hole drilled into it
attached to seat belt bolt
drilled some holes in some flat bar and bent it up to fit the seat mount
2x4 screwed to it
glued down the mdf with 3/16" area routed out so the box is flush
and its bolted in for now while glue dries (the alt hread will be unscrewed and box will be put in and bolted down to vehicle as well)
R.I.P!
(Nov-29-2009)
92 explorer
current build
Looks like poop. :buttlick:
haha i see you got my comment on youtube... to be honest i didnt even watch video
R.I.P!
(Nov-29-2009)
92 explorer
current build
so it starts out with box i built hmm like 6+ years ago when i started car audio not knowing shit about anything and its sat never used holding up my work bench haha
to begin with - no bracing and port only 4" deep so tuned to 48+ haha stupid i know
single baffle
(box under bench)
then started working out some ideas wanting to reuse as many old box components as i can before i throw them all out...... im sick of keeping this shit just laying around :angry2:
so old baffle for 2 18s from exploder wall played around with that idea and ended up not doing it
then found old baffle for 4 15s in explorer and figured that couldnt go to waste 4.5" thick stacked mdf haha
heavy little bastard
cut her down to size with table saw
now for some re enforcement haha 10' of 3/16"x4" plate and 16' of 5/8" all-thread
ready for glue
and steel plate to clamp down (1 on top 1 on bottom of port)
R.I.P!
(Nov-29-2009)
92 explorer
current build
so 3 layers of plate (and yes i know its crooked drilling threw 5"+ of mdf it didnt go so straight and curved off a little
inside the box
nuts welded to bottom plate
plate between port wall and mdf brace
a shit ton pl400
still need glue in some washers to the bottom
and onto more all thread 3/8" and 1/8" plate
and my rig haha
R.I.P!
(Nov-29-2009)
92 explorer
current build
drilled out the holes in sub basket to make room for new screws
and now onto some wood work
using box as bench
Mhmm new baffle
as you can see its routered out to make room for plate
and that is where we leave off
R.I.P!
(Nov-29-2009)
92 explorer
current build
got some new hardware today
hard to see photo but the wall is in and bolted to seat belt bolts below
still got a lot of work to do but shes in and i'm happy with it as of now
(and yes the baffles are right together its just the old one was rounded over slightly so looks like crack/void)
plan on tinting windows tomorrow and doing some more work on box adding 2x4s and shit
R.I.P!
(Nov-29-2009)
92 explorer
current build
