Noobie questions please, Answer ASAP
Yes i have made a bit of progress, i got it all wired up but there are still some spare wires that i am not sure what are for.
Ontop of all thease wires : ( had no problem with )
2001 GMC Jimmy Car Radio Install Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
I have the following extras from the vehicle :
Grey
Black(speaker thin)
dark blue
purple with white stripe
What role do thease wires play ? Is one of them going to be the accsessory ? Because there where no 2 yellow wires & after going yellow/brown for a speaker i have no yellow for acssessory.
Id appreciate a more kind attitude, I announced off the bat i wasnt sure how to install decks, This is my first one. I do builds, But i never am bothered to do decks. This one is pretty hard im hearing so lay off man. I am doing my best, & we are all learning along.
I would just bypass the steps you are taking and do one of two things. Go online and order a harness, or wire everything myself and forget about the factory wires. Have you tried to print out a copy of the head units wire diagram?
2000 GMC Sonoma
AQ20 FTMFW!
4 DC XL 15's
Cadence ZRS-C9
Infiniti Kappa 3.5's and 6x8's
Bravox 6.5 components
Yeah man, Read above. I got it all wired up there are only a few spare wires from the factory vehicle its self everything else from the harness i have in its spot.
But I am missing an acsessory (non-constant) Lead from the vehicle. So i am wondering if it is one of the wires i have left over spare ?
Read my above post again. It lists what i used, & what i have spare.
The only thing i have on my H/U Left that needs to be plugged is the Acssessory (atleast on the audio side of things ) & the stupid parking break.
Ok so instead of trying to track down the accessory wire in the trucks harness, just connect the yellow accessory wire to the fuse block to something that only gets power when the truck is on, like the radio fuse.
2000 GMC Sonoma
AQ20 FTMFW!
4 DC XL 15's
Cadence ZRS-C9
Found a blue wire that got snipped from the origonal harness, placing the unit back in it touched the power & all of a sudden the clarion came on, so i stripped that wire & vwolla. Only problem is my battery is dead in my car now :(
Ill get vids tomarow !
http://www.youtube.com/watch?v=CcUmjmkPz7c
Fully working now exept it aint putting out any sound, just beeps and stuff when you push buttons nothing from the speakers.
(music was edited in) That should narrow it down for somebody who has more experiance with decks than i do. I am thinking somthing to do with the impendence as i wired them 100% correct.
  • Who's Online   1 Member, 0 Anonymous, 433 Guests (See full list)
