Justins Jeep 12 15s DC 9ks VID
should be sweet you going with those amps you told me about at melos last month? or you change up
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
its look good so far!
cant wait till this is finished
and what 5ks are you going to run with it
sub'd for sure
thanks man
ya diff amps im in between couple companys now to many choices and everything haha
watever you deside on should sound good, maybe all DC :)
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
you said a 160?? isnt that box sealed???? :ehh:
anyways good job, looks sick already
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
it was doing 55's with the woofers barely seeing any power.
Cone is king, my friend.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
how much power did it used to have?
I'm gonna let Justin chime in, if he wants to say how much clamped power the woofs were actually seeing.
under construction
u hate c-fizzy?
