Audiopipe amp? total shit or good?
Mattintc10
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
You can run them fine at 1 ohm. The 1500. And tooshort.. I don't own the 3000 but I know it is just two 1500s in one case so I didn't know if it still acted as hooking up to 1500s or not. The 15001D and 18001D ARE one ohm stable. The 3k is 2ohm stable since again it is two 1500s together. Which you can actually get two 1500s cheaper than the 3000 I think. On eBay the 1500s can be found for $165 shipped and the 1800 $199 shipped
the problem.....
there is 2 1500's per case there linked inside...now here is the issue.
each amp is capable of a 1ohm load there bridged meaning each board or 1500 in that case even though it is seeing a 1ohm load. each amp will be running at .5 ohm load!
get it ?
95 Civic Coupe
Pioneer AVH-P7600DVD
Kinetik HC-1200 In Front
Kinetik HC-2000 In Rear
Memphis 16-MCA3004
2 X Memphis 16-MCD1000 With Maxxsonics MLX-100
2 X DC LVL 4 XL 12's
Pioneer Premier TS-C720PRS In Door's
Kenwood KFC-6982ie In Rear Deck
All Memphis Wire/Rca's and misc.
the problem.....
get it ?
Yes but 1 channel = 1500 watts and you can run it at 1 ohm and the other channel same thing go look at audiopipes site they say you can run each channel at one ohm and running both bridged at 2 ohms
my buddy ran his at .7 on 3 fi ssd's and it did good so i wouldnt worry about 1 ohm
I am talking about the AP30001d ...yes the 1500 can be run at one ohm no problem.
but as i stated in last post if you run the 3000D at 1ohm each board will see .5 ohm
95 Civic Coupe
Memphis 16-MCA3004
the problem.....
get it ?
wtf are you talking about its a 2 ohm bridge stable amp. if your that fuckin stupid to run it at 1 ohm thats your own damn fault
2015 silverado crew cab
nothing atm but soon...
OMFG people do not read what your saying very well........
1500 per channel yes at 1 ohm per channel,
but YOU CANNOT NOT BRIDGE THIS AMP AT 1 OHM !
95 Civic Coupe
Memphis 16-MCA3004
  • Who's Online   2 Members, 0 Anonymous, 1069 Guests (See full list)
