looks good, ive heard some good setups with those subs in person
but i kinda looks like the port piece in the center is not quite in the center
yeah it isnt straight i put that in at the last second i have a btl now tho but my amp keeps shutting off so i guess that means i gotta get a deep cycle batt and a high output alt
Currently in a build
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
Pioneer AVH-P2300 (next purchase)
High output alt 150 amps
could be wiring it wrong and it's going into protect mode, or maybe you're clipping it to death
2004 Volkswagen GLI
1 10" Skar VVX
^^^ Looking for an amp to run it, Pm me if you have one ^^^
it could be just cause its a cheap amp but it only happens when i turn it up it shuts off i checked my ground and everything it all seems fine im getting a new hifonics amp or a planet audio amp soon tho then im upgrading to 0 gauge
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
next time you turn it up look at the amp and see if the protect light turns on when it turns off
2004 Volkswagen GLI
1 10" Skar VVX
ok i will check it out
but i did run the btl free air with an old rockford fosgate 150 watt amp and i could turn it up all the way and it wouldnt loose power so i think my batt is almost gone, i mean i havent changed the batt in like 2 or 3 years lol
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
