peacedisturbance Posted October 2, 2010 Report Share Posted October 2, 2010 im new to the forum so heres an old vid i have a btl i just need to make a vid Quote Currently in a build 2 BTL 18s 1 AQ 2200 4 Kenetic hc 600s Pioneer AVH-P2300 (next purchase) High output alt 150 amps Link to comment Share on other sites More sharing options...
fritosaregood Posted October 2, 2010 Report Share Posted October 2, 2010 looks good, ive heard some good setups with those subs in person but i kinda looks like the port piece in the center is not quite in the center Quote seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970 Link to comment Share on other sites More sharing options...
peacedisturbance Posted October 2, 2010 Author Report Share Posted October 2, 2010 looks good, ive heard some good setups with those subs in person but i kinda looks like the port piece in the center is not quite in the center yeah it isnt straight i put that in at the last second i have a btl now tho but my amp keeps shutting off so i guess that means i gotta get a deep cycle batt and a high output alt Quote Currently in a build 2 BTL 18s 1 AQ 2200 4 Kenetic hc 600s Pioneer AVH-P2300 (next purchase) High output alt 150 amps Link to comment Share on other sites More sharing options...
Emoxihax Posted October 2, 2010 Report Share Posted October 2, 2010 yeah it isnt straight i put that in at the last second i have a btl now tho but my amp keeps shutting off so i guess that means i gotta get a deep cycle batt and a high output alt could be wiring it wrong and it's going into protect mode, or maybe you're clipping it to death Quote 2004 Volkswagen GLI 1 10" Skar VVX ^^^ Looking for an amp to run it, Pm me if you have one ^^^ Link to comment Share on other sites More sharing options...
peacedisturbance Posted October 2, 2010 Author Report Share Posted October 2, 2010 could be wiring it wrong and it's going into protect mode, or maybe you're clipping it to death it could be just cause its a cheap amp but it only happens when i turn it up it shuts off i checked my ground and everything it all seems fine im getting a new hifonics amp or a planet audio amp soon tho then im upgrading to 0 gauge Quote Currently in a build 2 BTL 18s 1 AQ 2200 4 Kenetic hc 600s Pioneer AVH-P2300 (next purchase) High output alt 150 amps Link to comment Share on other sites More sharing options...
Emoxihax Posted October 2, 2010 Report Share Posted October 2, 2010 next time you turn it up look at the amp and see if the protect light turns on when it turns off Quote 2004 Volkswagen GLI 1 10" Skar VVX ^^^ Looking for an amp to run it, Pm me if you have one ^^^ Link to comment Share on other sites More sharing options...
peacedisturbance Posted October 2, 2010 Author Report Share Posted October 2, 2010 next time you turn it up look at the amp and see if the protect light turns on when it turns off ok i will check it out but i did run the btl free air with an old rockford fosgate 150 watt amp and i could turn it up all the way and it wouldnt loose power so i think my batt is almost gone, i mean i havent changed the batt in like 2 or 3 years lol Quote Currently in a build 2 BTL 18s 1 AQ 2200 4 Kenetic hc 600s Pioneer AVH-P2300 (next purchase) High output alt 150 amps Link to comment Share on other sites More sharing options...
