Alternator going bad?
Hey guys i have a question. When i turned my car on today my brake light came on along with the battery light. I put a DMM on the battery at rest and it was reading normal around 13, but when i started the car up the voltage started to climb and it was surging past 18v so i shut it down. Is it time for a new alt?
(2)12" Rockford Fosgate P3's
(1)AudioQue 1200D
(1)AudioQue 4x90
6.5" Infinity Kappa Components
(2)6" Elemental Design e3.6's
6x9 Infinity Kappa Coax
JVC Arsenal H/U
wow thats not good. were you checkn it with dmm when it did that? or just going off of dash gauge? the brake light coming on at the same time is weird almost sounds like a dash short and gauges are acting up. but if you got 18v with the dmm then the voltage regulator sounds like its bad
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Hey sorry for not getting back soon enough, nut everything was tested on DMM, and the alt was stock. I took it to a shop and they said it was the regulator. So now its time for a new alternator.
(1)AudioQue 1200D
(1)AudioQue 4x90
JVC Arsenal H/U
  • Who's Online   0 Members, 0 Anonymous, 1501 Guests (See full list)
