want alot more spl out of sound system
Use Torres' box calculator, it'll give you dimensions and stuff and tell you the tuning. I'm assuming your blazer is similar to my 2 door explorer, so in theory you have room for a lot more. you should definitely be hitting higher than 128 though, on 1 18" i'm hitting somewhere in the mid 140's, but once i build a new box i'll probably get higher.
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
Something has to be wrong with your set up if you aren't even breaking 130 off of 2 T1 12's, I did a VERY budget friendly build with 1 MB Quart Reference 12 in 1.75 tuned to 32 hz and did a 129.8 out of a trunk car with a ski pass.
2002 Chevrolet Trailblazer LT
Jensen VM9223 | Pioneer Premier Comps | Audiopipe AP15001D | DC Level 4 XL 18 in 6 cubes @ 36hz | Deka 9A78DT | Knu 4 Gauge | Big 3
  • 1 year later...
i figured out y my sealed box was hitting very hard. my box was 1 cube to big so.... but its all good im gunna be building a box tuned to 33 or 35hz subs bacc port bacc but thank you for the advice
Wicked 4 play car club
2002 Chevy 2 door blazer
Real soon setup
head unit: PTID-8920B
subs: 4 12's or 2 15's hevent made up my mind on brand,ported at 33hz
amps: for sure two RF 300.4' for mids and highs, 3sixty.2. stuck on wat sub amp ill be using
power supply: big 3 1/0, 2 runs of 1/0 power wire and 2 runs of 1/0 ground wire bacc to the second battery, 8awg, 4awg and depending on the sub amp 4 to 1/0 power and grounds for it.
speaker wire: 12awg speaker wire and 8awg for subs
speakers: 4x6's dash, 6 1/2 components doors, 5 1/4 components kicks, and 6x9's back. all Infinity Reference
misc.: 8000k hid low beams/projector headlights, 3/3 lowering kit, D3400 xspower batt up front and rear, ad244 145 amp alternator
