want alot more spl out of sound system
i have an 02 chevy 2 door blazer with 2 t112d2 subs and a 1000.1bd rockford amp and im maxing at 128db. without more subs how can i increase my db? second question how can i make it hard for people to breath when the bass hits? a buddy of mine has an impala with 2 12's and if i breath when the bass hits it hurts. i want that effect outta my sound system. any ideas let me know
Wicked 4 play car club
2002 Chevy 2 door blazer
Real soon setup
head unit: PTID-8920B
subs: 4 12's or 2 15's hevent made up my mind on brand,ported at 33hz
amps: for sure two RF 300.4' for mids and highs, 3sixty.2. stuck on wat sub amp ill be using
power supply: big 3 1/0, 2 runs of 1/0 power wire and 2 runs of 1/0 ground wire bacc to the second battery, 8awg, 4awg and depending on the sub amp 4 to 1/0 power and grounds for it.
speaker wire: 12awg speaker wire and 8awg for subs
speakers: 4x6's dash, 6 1/2 components doors, 5 1/4 components kicks, and 6x9's back. all Infinity Reference
misc.: 8000k hid low beams/projector headlights, 3/3 lowering kit, D3400 xspower batt up front and rear, ad244 145 amp alternator
You need a properly ported box for your subs. Tune higher for spl numbers, lower for groundpounding bass. Also you're probably not going to make it hurt to breath without better subs and a lot more power.
What's ur box like, the best application for SUV's is sub up port back. I agree better subs and more power if you want to start hurting some lungs and make peoples vision all blurry.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
FIRST OF ALL i was reading ur sig DO NOT add pionner shallows!!!! get a box built... ported... have it tuned according to the music u listen to. somewhere in the low to mid 140s is very do able. its all in the box design. mixing subs is a bad idea VERY BAD IDEA WHEN THEYRE SHALLOW SUBS
="Impact"]
pioneer 4200 dvd
4 sets aa carbon mids
2 sets rockford power t1 tweeters
rockford power t400.4
rockford power 4inch
DC 175.4 DC 3.5k (soon to be 2)
2 DC XL 15s
The artist formally known as willie3719
There are 12s that are 150rms and there are 3krms 12s. Making it hard to breath, need ported,lot of power and Cone area. But or 135+ is easily achievable. Low tuned will give you the chest pressure and shaking, high tuned will put out SPL numbers like you want. It's whatever, in a blazer you could go bigger.
money on it u got a sealed box and thats your problem
so here is my suggestion if u want to not be able 2 breath
buy 2 more t1's
build a ported box to like 33 hz or lower
send the bd 1000 to me as a gift :pardon:
and then go buy a sae 3500 and start banging
1) lookj to left
2) NOTICE BLKUE
3) ME > Y9OU
4) that is all
buy 2 more t1's
and then go buy saz3500 and start banging
edit for line
="Impact"]
pioneer 4200 dvd
2 DC XL 15s
well i updated my signature. let me know wat u think bout the box
Real soon setup
its still sealed???!!! u cant spl sealed. ported is spl
="Impact"]
pioneer 4200 dvd
2 DC XL 15s
well i gotta get more wood for that. but im so stuck. i called rockford with my measurements and they told me to leave it sealed now theyre telling me i should be hitting more then 128db with just the 1000.1BD amp. so i dont know wat to do. i wish i knew how to make a ported box for my subs tuned to 32hz
Real soon setup
