dirtboi22 Posted October 6, 2010 Report Posted October 6, 2010 I have a Hifonics vii zues (class AB) 900 watts rms @ 4ohm which doesnt have a built in crossover (run my rca's to a poweracoustic crossover then out to the amp.)it doesnt sound bad on my RE SX 15 (dual 2), but when i hook up my little rockford p5002 (Class AB) 250 watts rms @ 4ohm it sounds louder!? WHY IS THIS??
hdorre Posted October 6, 2010 Report Posted October 6, 2010 The difference between the two classes is efficiency. Class ABs are generally around 50% while class Ds are around 70% at 1 ohm. The RF may seem louder because of voltage drops. Hifonics usually lose a lot of power (18% per volt IIRC) from voltage drops. RF isn't as bad with drops and is under rated. I don't see where the title comes into play with these amps because you said they're both AB On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
dirtboi22 Posted October 6, 2010 Author Report Posted October 6, 2010 yea, thats my bad i just saw where it say AB vs D. But i have 2 batteries and i never saw below 13 volts on ethier amp...?
dugee81 Posted October 6, 2010 Report Posted October 6, 2010 the rockford is rated 500 @ 12.5, will probably do a tad bit more than what it is rated for. hifonics is rated 900 @ 14.4, and will lost a considerable amount of juice as the voltage is lowered in the 13's. the rockford is running around the same voltage, and is even more efficient because of it. edit: this is just a possibility, i was just throwing it out there. 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
