this is the best you'd get idk if the port area is too small tho, 36.75in^2
sorry the port is two wide. The only way we are going to have to build is to fit the triangle from our back seats to get the extra area so basically we will build it with one common wall,
just a question is more cu per sub better if you are under powering a sub?
yes use about 2.25 ft^3 per sub with lower levels
EDIT: or less
does it hurt the sq by any chance or whats the problem with more cubic feet
What about sub up/port back? I dunno what car, what you want, etc. so it may not work for you, just an idea. If everything won't fit on one side, use two sides lol.
Edit-bigger box with less power--more airspace means less cone control, so less power counteracts that. small boxes have better cone control, letting you overpower it and still be (somewhat) safe.
Edited by bassfiend316
I'm not sure... i always over power my subs lol
im feedin about 450-500 rms each to my sa 12s which are underrated and can probably take 1k each and still be fine, but im not guna risk anything. Im guna build a box with zero common walls and ill let you know if 3 is the lucky number
You could go with 2 4" pvc ports between the subs but not sure if its enough port area for those subs, will this box be sealed from the trunk?
The reason i ask is you can port off axis firing from the side into the trunk.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
dont know what you said bro
