extra battery??
im suppose to pick up some more 0/1 wire and another battery this weekend, but now im wondering if i really need it. this is what is getting used, i have a sundown saz2000, and a sax 125.2. i plan on running it at .6 ohms next season. for electrical i have big 3 done, 220amp alt, 1 run of 0/1 front to back, odyssey 1500 up front, and a odyssey 2150 in the back.
now is it worth it for me to jam another battery in the back? i know the more the better, but is it really needed? also, would i benefit from another run of pos front to back??
im just thinking if i can save the money i should. thanks
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
3 Sundown Audio SA-12's
Alpine H/U
RF Power Comp set 6.5"
RF 3 sixty line driver
5.25 cubes @ 31hz
it all depends on what your voltage is @ full tilt. adding another run reduces resistance betweens batteries and the alt, and adding another battery in the rear will add more reserve. what is your voltage like?
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
at full tilt with the amp at 2ohms, at idle sits around 13.9 + - some depending on note being played, and on a reg basis truck runs at 14.4 volts
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
i think you should do fine............ just my opinion. i would start to worry if i was going down to the mid/lower 12's. mine does at times even with my RPM's in the 1200-2000 range. i need more battery power
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
if your voltage is 13.9 or around there at full tilt, then you should be fine. some cars don't even charge that high. stock car and, nothing on.
MY TRUCK BUILD - 1976 F-100 Ranger. Fully built 482 big block, 4 DC lvl4 15's in a blowthrough, plenty of custom fabrication.
MY HATCH BUILD - 1993 Honda Civic DX Hatchback . Clean daily driver, dropped, subtle customization.
yea, but again the amp is running at 2ohms though..
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
going from 2 ohm to 0.6, you might want to add another battery because of all the extra current that will be pulled. only way to know for sure is to do tests! can you wire it down this way right now?
OH! and by the way, you said you will be running a 2000D @ 0.6. your sig says you are running a 3500D right now??
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
sig is old, and yes i can wire down to .5 only. but the subs wouldn't take it.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
  • Who's Online   0 Members, 0 Anonymous, 1347 Guests (See full list)
