gtasound Posted October 11, 2010 Report Posted October 11, 2010 I've decided to rework my current trunk box from a 3 12 rear facing sub and port to a 2 12 front facing sub and port box sealed from trunk. Question is for 2 12s, would it be better to isolate the box chambers and slot port each in the side or center, or make one common chamber and slot port them at the side or center? Goal - spl Car - lincoln ls Subs - 12" powerbass xxxl Stefan Brijlall GTA Sound Pro DJ's www.gtasound.com
Socky Posted October 11, 2010 Report Posted October 11, 2010 Ive heard port on drivers side helps on the numbers sealed from trunk. Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
Hugh G. Rection Posted October 12, 2010 Report Posted October 12, 2010 would it be better to isolate the box chambers and slot port each in the side or center, or make one common chamber and slot port them at the side or center? this depends. are you gonna be running a stereo configuration, or mono configuration? Owner of BigAss Ports
gtasound Posted October 12, 2010 Author Report Posted October 12, 2010 Mono Stefan Brijlall GTA Sound Pro DJ's www.gtasound.com
