charli3 Posted October 12, 2010 Report Posted October 12, 2010 Can speaker wire max out, I went from a kenwood 600 rms to a memphis 1500 rms but it doesn't sound much louder at all. Im using wiring from a rockford wire kit
Freshman6969 Posted October 12, 2010 Report Posted October 12, 2010 Can speaker wire max out, I went from a kenwood 600 rms to a memphis 1500 rms but it doesn't sound much louder at all. Im using wiring from a rockford wire kit what subs are you running? and and wire will just burn if to much current is put though it Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog
charli3 Posted October 12, 2010 Author Report Posted October 12, 2010 One dc level 4xl 12". Also im not quite sure with my wiring I think I have it wired at 2 ohms but a 4 ohm wiring diagram looked exactly the same
Boon Posted October 12, 2010 Report Posted October 12, 2010 I crammed about 10kw through some 10ga for a while. I think you're probably OK. 10.x volts fo' life!
