masterbarber Posted October 12, 2010 Report Posted October 12, 2010 Ok here's the deal; I have my wagon wich im putting a new system on, my factory alternator with the Big 3 upgrade was hiting 14.1 volts. But with the lights on and the system bumping the lights go low. So i decide to upgrade and bought a 165amp high power alternator and 2 extra bateries. I just installed the bateries with 0 gauge and the new alternator, and when i crank the car on its hiting only 12.0 volts. Why? What im doing wrong? I dont get it . I can change the alternator if that its the problem cause it has warranty. Can anyone give me an advise on this issue? Thanks in advance 1 15" DC Audio lvl 5 1 DD M4a Beyma 6.5 (4) RE tweeters (4) Orion XTR 500.4 Pioneer Indash 2 Dynasty UPS12-490MR batteries
masterbarber Posted October 13, 2010 Author Report Posted October 13, 2010 Anyone? 1 15" DC Audio lvl 5 1 DD M4a Beyma 6.5 (4) RE tweeters (4) Orion XTR 500.4 Pioneer Indash 2 Dynasty UPS12-490MR batteries
chapo123 Posted October 13, 2010 Report Posted October 13, 2010 what brand alt? Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
Guest Posted October 13, 2010 Report Posted October 13, 2010 165 amp? is that from the More_amps guy on ebay? i would return it and get your $150-200 or whatever back. his alts are crap. i would know.
Mosin Posted October 13, 2010 Report Posted October 13, 2010 For the system in your sig you should consider a slightly larger charging system. Swap the old alt back in and see what your voltage is at. What do all the batts rest at? Derp.
