My little car (and the giant install):
Sound Specs:
Head Unit Alpine IVA d511rb
Amplifier Audio System Front: Radion 90.4
Amplifier Audio System Kick: X-ion 280.2
Amplifier Audio System Sub Left: X-ion 280.2
Amplifier Audio System Sub Right: X-ion 280.2
Equalizer / Signal Proc: Alpine PXA-H701
MidRange Speakers: Audio System X-ion 165
MidRange Speakers: Audio System Kickbass: Helon 165
Tweeters: Audio System X-ion
SubWoofers Audio System Left: X-ion 15 plus
SubWoofers Audio System Right: X-ion 15 plus
Wiring: Audison Connection
Batteries: (3x) Hawker 105Ah / 3500A
(original) Car Specs:
Engine
Type: Air cooled, Two Stroke parallel twin
Bore x stroke: 2.83 x 2.87 in.
Displacement: 36 cu in, 595 cc
Comp. Ratio: 8.0:1
Emissions Control: None
Valve Gear: None (1)
Power: 27hp @ 4200 rpm
Torque: 38lbs-ft @ 3000 rpm
Redline: 5000 rpm
Drivetrain
Transmission: 4 speed, column shift manual
Final Drive Ratio: 4.33:1
Gear Ratio Max Speed
1 4.08:1 19 mph
2 2.32:1 32 mph
3 1.52:1 48 mph
4 1.03:1 62 mph
R 3.83:1
Dimensions / Capacities (Wagon)
Wheelbase: 79.5 in.
Track F/R: 47.5 / 49.4 in.
Length: 138.2 in.
Width: 59.3 in. (59.5 in.)
Height: 56.7 in. (57.9 in.)
Ground Clearance: 6.1 in.
Curb Weight: 1355 lbs (1433 lbs)
Weight dist: 59 / 41 % (56 / 44 %)
Fuel Capacity: 6.4 gal.
Oil Capacity: None (2)
Water Capacity: None (3)
Chassis / Body
Type: Unit construction
Body Material: Steel frame with Dyroplast panels
Suspension
Front: Ind. lower A-arm, transverse leaf spring
Rear: Ind. lower A-arm, transverse leaf spring
Steering
Type: Rack and pinion
Turns, lock - lock: 3.2
Turning Circle: ~30 ft.
Brakes
Type, front: Drum
Type Front: Drum
Power assist: None
Wheels and Tires
Wheel size: 4 x 13 in.
Bolt pattern: 4 x 160mm
Wheel type: steel
Tire Size: 145-75R13
Tire pressure: 35 / 35 psi
Test Results (4)
Zero to 30 mph: 5.0
Zero to 40 mph: 9.1
Zero to 50 mph: 16.3
Zero to 60 mph: 30.3
Zero to 70 mph: NA
Standing 1/4 mile: 22.5 @ 56 mph
Top Speed: 62 mph
Original cost: 14000 East German Marks
(You might understand we did some changing/tuning so the current specs are "a bit" diffrent :yahoo: )
______Some people and performances are beyond words______
Chairman of the foundation "Propper-Droppers Holland" 2012
Founder of the European delegation of `Propper-Droppers' 2011
Dutch Champion EMMA SQ MultiMedia advanced 2010
European Champion EMMA SQ experienced 5 channel 2007
Dutch Champion EMMA SQ experienced 5 channel 2007
BeNeLux vice Champion dB-drag street-A 2007
Dutch vice Champion dB-drag ministreet-sedan 2004
_________________________________________
Propper Droppers is about deep, ground wobbling, elephant-and-whale stimulating Street Bass.
The deep stuff. We test at different frequencies from deep, to low to snake’s belly. (Like 20Hz anyone?)
  • Who's Online   0 Members, 0 Anonymous, 2320 Guests (See full list)
