Amplifier/Battery Combination
organshifter
i dont think they will and if they did it would be dirty as hell clip city i just had the kole trax 5500d and it was weak an no were close to rated power and i have upgraded elec with 2 power cells
Damn. I would have at least thought that PA 5500D's could do 2400RMS @ the right voltage.
I have three of these:
Boss Outcast L12 (Sonic page) | Actual Product Page
what subs are you using. and i use to build shit the cheap way and it works and sounds ok but it just dont last you get what you pay for, i have a cheap system in my work van and i go trew sub or two a month so realy its just wasting my money but its still fun to beat them to hell and back tho but i have fun with it and dont worry about blowing shit cause my subs are so cheap . but they hammer hard as hell. so its realy up to you but im done with cheap subs and amps. i was hard headed and would not listen to peps giving me advise. and belive me i dont have a pocket full of cash to blow ether. but your better off buying one thing at a time and then you will have something better in the long run.
My shit is cheap too. These subs hit hard as hell, but I don't have a decent enough amp the push them properly.
I feel you though. I was just trying to get something real quick, before the fam hits me up. Lol.
go with the audioque 1200 and it will push the crap out of them . way better than kole or poweracustic and its only 250 shiped. i realy dont think those subs would handle the 2200d so i say 1200 aq
What site are you referring to, so I can go check it out?
Edit: Nevermind, I hit up their page.
www.audioque.com
You sure that the AQ1200D can handle three subs properly?
Output Power 14.4V @ 1% THD
510X1 @ 4 ohm
870X1 @ 2 ohm
1200X1 @ 1 ohm
Output Power 14.4V @ 5% THD 1470X1 @ 1 ohm
I'm going to run my three subs in a series/parallel at 2.67 ohms. Seems like I'll be receiving less than 290W per sub (870W @ 2 ohm / 3).
how does those subs sound they look beefy
They hit hard Dee. Real talk man. And I only have 2 of them in a sealed enclosure right now with 1.2 Cu Ft airspace each. I can't run all three on the measly amp I'm using.
Does anyone have additional suggestions? I'm going to do the big 3 this week, possibly purchasing an HO alternator.
I'm sure that batteries are much better than capcells, but how do I sustain 16v on a 12v battery? Do I need to incorporate both, or will the amp pull all it needs from the second battery?
Anybody have any experience with any of the amps I listed? I know they're not the best, but I need more opinions. PA most likely sells more amps than all the other companies put together, so can someone who's running one now share their experience?
  • Who's Online   1 Member, 0 Anonymous, 457 Guests (See full list)
