trunk set ups, help me, 3 or 4 12s? amp??
this is my newest set up, i found it to be the loudest and most expensive.
kills the highs aswell i bet, retail must be a B! and i bet you recone it often? sexy nonetheless
I need clean the grounding area down better and that will probably solve it but it's not THAT big of a dim just a little bit. Just enough to notice.
And for cmam ain't that the truth LOL
put ur grd to negative of ur bat then? i heard thats better. and sand off ur paint when u grnd things
Edited by __d_a_v_i_d__
And I know to sand off the paint when I ground things :P
And the very best place is directly to the frame if you have one.
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
well then i would personally just work with the 2 12s. subs up like that with that tiny port wont get too loud.
my 12s in a trunk when i had them
You might be able to fit 3 12s depending on how wide your trunk is.
you could wire it to .66 to the crescendo amp and it would work.
looksvery loud.
oh wow can i really do that with 3? tell me how bro!!!
cuss i know 4 (parallel) = 0.5 ohm load . but 3 the lowestit showd me wss (series/parallel) = 2.67 ohm load so i was wondering about parallel in 3,
i have an 03 impala pretty wide
edit: and u past the 150 mark already with the 2 12s right?thats fkn sweet!!
looksvery loud.
yea i broke the mark in this car and in my buddys truck with 2 12s
youll have 3 dual 4 ohms subs. parallel each sub so you have 3 2 ohm subs now, then parallel all of the subs together and you get .66 ohms
Man i aint baggin your sh**. but try metering MECA competition Style at the headrest. dash and kick numbers dont impress. noone here's that. you dont stick your head against the dash or in the kickpanel to hear it.
in texas they still meter in the kickpanel tho
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
No use for that hear, the way ppl meter around here is the kick so when i test, i test in the kick. and ppl on here like dash.
No one listens to 70hz farts either, but thats what some ppl play.
nothing against you, just my view on other things too.
but i do agree and hate when someone post kick numbers, then someone says, you never stick your head in the kick for music. and then say you need to meter on the dash sealed up.
  • Who's Online   0 Members, 0 Anonymous, 1559 Guests (See full list)
