Have any of you ever worked with masonite? its what they make clipboards out of, its strong as hell, its like $8 for a 4x8 sheet, its strong as all getout, i used it to make my door panels and a false floor in my jeep, and was only out $10, but its not all heaven, unless you have a serious staplegun good luck getting anything through it, i had to pre-drill holes and then staple it when i was doing my doors, by the way, you want the solid sheets tho, not the perferated sheets, its a LOT stronger.
just a head up for any of you need something thin and strong to make something out of.
Edit: also good for speaker countersink baffles.
Edited by BanginOnABudget
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
wow thats exactly some stuff that i need its like you have ESPn lol
hahaa. they have it at lowes and home depot, but idk about anywhere else.
what size sheets? because the thin wood cover over top of my spare tire is somewhat "U" because of the weight of the box and battery on top i need something stronger but thin so my box can still fit
I don't fuck around. I go from zero to I hope you die in less than 2 posts
build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
im pretty sure they only sell its in 4x8 sheets but they might sell it in a 4x4 sheet if you ask. i'd say buy a whole sheet and double up the wheel cover, when you drill the masonite put a 2x4 under the spot you're drilling so you dont blow the back out. its hella strong when you have it put together right, it seems flimsy in the 4x8 sheet but when you cut it up and it looses mass, it gets hella strong.
