which amp
g6ryder
Which amp would be best for my sub which is an orion hcca12 dual 4 ohm
Autotek mm4000.1d
DAT 2500.1
both amps will be in 2 ohm
www.wooferwarehouse.com
What are the spec on the DAT?
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
But very underrated read its get 2k+ at 2 ohm and 3k+ at 1 ohm
600wrms x1 @4ohm @ 13.8 volts
1200wrms x1 @2ohm @ 13.8 volts
2500wrms x1 @1ohm @ 13.8 volts
Specifications
PCB: double layer
Dual 1/0 power and ground inputs.
S/N : 95.2dB
T.H.D % : 0.08
Idle current: 2.24A
Efficiency: 82.6%
LPF:50-250, 12dB/oct.
Subsonic : 15-50Hz ,
input sensitivity : 0.25-7.5V
Frequency response:15-350Hz,
Phase adjustment: 0-180 degree
protection Temperature; 70
protection Voltage: >8V
That's really hard to say...
DAT is very beefy, but I don't believe they are still in business. If something goes wrong, you're outta luck.
I was never a fan of the new Autotek. I'm not convinced that it can produce state power.
Why is your option limiting on just these two amps?
Well I'm open to any amps that will put 2500+ at 2 ohms just the 2 I've seen and liked.
why not find something rated at 2500 watts at 2 ohms like the: kicker 2500, RF T2500, jbl GTO2400, old orion 2500, or AP3000
or i would get the AQ3500 or a RF T4000
ur signature says u have a colossus...why not just keep that. or if ur on a budget check the audiopipe 3k
="Impact"]
pioneer 4200 dvd
4 sets aa carbon mids
2 sets rockford power t1 tweeters
rockford power t400.4
rockford power 4inch
DC 175.4 DC 3.5k (soon to be 2)
2 DC XL 15s
The artist formally known as willie3719
  • Who's Online   0 Members, 0 Anonymous, 906 Guests (See full list)
