3 way component help
uhoh_45
so i'm looking to do a full 3 way setup and was looking into getting
4 Eminence APT-80 Super Tweeter with 80° Conical Horn
4 Tang Band W3-319SF 3" Full Range Driver
and 4 Tang Band W5-1138SM 5-1/4" Neodymium Sub-woofers
now see i dont know much about crossover and by much i mean anything so i was wondering which of these crossovers would be best to go with?
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
bump- i was just thinking for the crossover would i go with a home audio 3 way- i cant find any built for the car
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • 1 month later...
First and foremost, what are you trying to do?
A three-way set up is mainly to get the best reproduction of music because the difference size speakers are able to produce the correct frequency accurately. From your selection of speakers it appears the goal is to be loud and clear. Which by all means is hard to do as well. To make the components you selected fit you'll have to make some modifications I assume. I'd recommend going with a bigger mid-bass driver if you can do 8's,do it if not 6.5's will work just as well. 5.5's are just a little on the small side for a mid bass and a little on the big size for a dedicated midrange (but can work). I like your selection of size for the 3" and those tweeters should SCREAM!!! The Hoopty and Steve's Hoe are designed to be loud and clear and was achieved with multiple 2-way 6.5 components and a 10" sub in each door. I and many SQ guys run 3-way set ups in their vehicles and use active crossovers which I recommend as well. Any "cheap" 3-way crossover would work to get you started but you'll need to dedicate an amp/channel per speakers, an amp for tweeters, an amp for midrange and an amp for midbass. I hope this was helpful.
  • 3 weeks later...
it actually was rather helpful
and i yeah i had a 2 way setup in my explorer with no crossovers, dedicated amps and my memphis 3way
when i do get serious bout this i will look to you for more detailed help and recommendations
once again thank you Kimo.
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 1942 Guests (See full list)
