merk_master Posted October 25, 2010 Report Posted October 25, 2010 AP1500d @ 2ohms and 400 Watt RMS pioneer @4 ohms on a stock alternator( 110 amps) would 2 Kenetik KHC1200s in the trunk be enough? Quote hopeful noob
Slawsen Posted October 25, 2010 Report Posted October 25, 2010 (edited) 1 batt in the back as long as you had 1 up front would be perfectly fine... Then again as i'm sure you know you can't really have too much power.. Edited October 25, 2010 by Slawsen Quote 00' Nissan Xterra Always under construction :] HU: Pioneer DEH3100-UB Mids & Highs: Kicker DS Component Set & Crescendo tweeters Mids & Highs Amp: Rockford 150.2 Subwoofer: 2 DC Audio LV 4 18"s Subwoofer Amp: Hifonics Brutus 2005d you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
merk_master Posted October 25, 2010 Author Report Posted October 25, 2010 Well I was thinking more along the lines of front battery delete/relocate to trunk . hence 2 batteries in the trunk. Also Going to do all wiring in 2 gauge. (big 3) runs to trunk) and batteries to amps Quote hopeful noob
Slawsen Posted October 25, 2010 Report Posted October 25, 2010 Well I was thinking more along the lines of front battery delete/relocate to trunk . hence 2 batteries in the trunk. Also Going to do all wiring in 2 gauge. (big 3) runs to trunk) and batteries to amps Then the 2 hc's in the back will be fine. Quote 00' Nissan Xterra Always under construction :] HU: Pioneer DEH3100-UB Mids & Highs: Kicker DS Component Set & Crescendo tweeters Mids & Highs Amp: Rockford 150.2 Subwoofer: 2 DC Audio LV 4 18"s Subwoofer Amp: Hifonics Brutus 2005d you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
Robert8252 Posted October 25, 2010 Report Posted October 25, 2010 What type of car. Running a audiopipe1500 and a Ed nine.4 400rms amp at 2ohm per channel all on 4 gauge wiring stock alt and and stock batt. Voltage doesn't go below 12.2 at idle after playing for a few minutes and is a solid 14.4 full tilt driving. Quote 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
merk_master Posted October 25, 2010 Author Report Posted October 25, 2010 (edited) Ok lol ,Its a 2002 Focus Sedan. I see 14.4 to 13.3 on 400 watts from my pioneer setup . would alot of voltage drop be predicted? Edited October 25, 2010 by merk_master Quote hopeful noob
Robert8252 Posted October 25, 2010 Report Posted October 25, 2010 What's the alt on that? My Taurus is a 140 amp max. Honestly big 3 in 0 gauge and you're probably good to go with that Quote 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
merk_master Posted October 25, 2010 Author Report Posted October 25, 2010 Its 110 factory. Id rather stress my alt less with more batterys Quote hopeful noob
Robert8252 Posted October 25, 2010 Report Posted October 25, 2010 Keep the stock batt and put one extra in the trunk. Should be perfectly fine Quote 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
merk_master Posted October 25, 2010 Author Report Posted October 25, 2010 I always thought mixing batteries was a bad idea? Quote hopeful noob
