I have done the big 3 on my car with 1/0 guage but the alternator to battery wire runs to my fuse box then to the battery. I kept that wire and added to it. My question is did I do this right or should I run a straight run directly from the alternator to the battery and bypass the fuse box still leaving the stock wires to the fues box. I don't know if my voltage regulator is inside the alternator or external or if that matters. Thanks. This is a must know for me. I can't find the answer anywhere.
Just add on to the factory wiring, mine goes to the fuse box as well, but I just ran the 1/0 straight from the alt to the battery....its simplest to just leave the factory wiring connected.
Edit: Just really read your post, you are fully correct in the way you did it
Edited by CaptainzPlanetz
¿ǝɯɐƃ ǝɥʇ
when i did my big 3 i just ran a wire str8 from alt to battery but i put a 150amp fuse inline of it just in case, and ground from engine block to chassis, and from battery neg to chassis
i need to run a wire from my battery neg to my alt casing
ied run the wire from alt to battery, most people say no need in fuse, i say fuse everything cause a fuse is always cheaper than a new car :)
anyways good luck
and i was told its best to leave factory wireing cause how much can it hurt with running 1/0 and 4guage from alt?
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
On your setup since you are on a stock what was it like 70 amp alt, it doesn't even matter if you upgraded that wire or not.
But normally you would want to run direct to the battery and make sure the vehicle stuff is still all powered off the battery which just about every car manufacturer under the sun does it that way so you could have just went straight to the battery and I agree put an inline fuse on it, IF the battery crapped out bad enough to create a short, if you weren't fused then the battery would take the alt out with it, but fused, it would just pop the fuse and open the circuit protecting the alt, this matters ALOT when you have HO alts.
Edited by AMI CUSTOMS
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
I have a stock 115 amp alt and after I did the big 3 I went from 13.7volts at idle to 14.3 volts....
¿ǝɯɐƃ ǝɥʇ
My stock alt is 110 amps. There is 8 guage wire stock. I have 1/0 from battery negative to chassis and 1/0 from enjine block to chassis and I just want to do the final wire correctly. So what you guys are saying is that I should just run directly to the battery from the alternator ( leaving stock wire inplace to the fuse box ) and that won't affect anything with the computer or voltage regulator? It's a genesis coupe and I don't want to mess it up. Also what size fuse to use and should I put it close to the alt or the battery?
Edited by Moley
If you are gonna use 1/0 with a high strand count use a 300 amp anl type fuse.
Evo X build log
Your upgraded grounds did that, not the alt wire.
Evo X build log
Thank you. Means alot. I will go ahead and go straight to the battery and fuse it according to wire size. I think I will place the fuse close to the battery.
