The Black Nasty - Wall build log "2011 Season, Rebuild 2012!!!!" - Quest for 160+ db!!!
dont know if he wants his name out there but hes a local guy i met that use to work for a bad ass amp company that is no longer around. hopefully they work for me i will post numbers when i get them back. where are you located?
Arkansas!!! What is name of said bad ass amp company?
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
I think I misunderstood- you gained 1db with your daily power over your comp power the last time you metered? :trippy:
I gained 1.5 over on daily power, best I had did before on outlaw style was 157 and I did a 158.4 with a loose sub. I didn't run it on comp power cuz I didn't figure that one woofer would hold together.
Evo X build log
linear power and my m4s are making over 5k a piece now on the bench waiting for the other one to get finished
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
And these are bigger then the aq3500s? Cuz mine make that now....
Evo X build log
they are rated at 3500 at 11.9 the 5k is at same voltage and above 1 ohm im hoping for a 35% increase in power
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
So at 14.4 this a 7k amp now you are saying? And you are gonna run it at what, .7 ohms? So 8k amp? Just guessing....
Evo X build log
thats what im hoping. i run my amps strapped at .7 so they see .35. a ? how much gain in db"s do you think i mite see going from 9k to 14 to 15 k
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Going from 9k to 15k I would think 2.5 db and 2 db at the least, you are almost doubling power, when I went from 5k to 9.2k I picked up exactly 3 db.
Evo X build log
kool im looking for at least 1db that would be great if i get more from it.
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
