Ok this one is a bit more easy
I've got 8 awg power wire ran.
I plan to hook up the dash and 4 doors with amps (40w rms x2 + 60w rms x4)
Current sub is wired for 500w RMS - not changing anytime soon.
2 Q:
What thickness of wire should I get for all this?
Is the current 8awg going to limit the amp?
It hasn't blown a fuse or anything, but the amp does seem to be cutting off randomly (probably due to the box but that's another issue)
I have a 2 way splitter already but the out-lines seem too thin (18 awg)
second question:
the speaker wire I bought is 16awg.
the speaker wire in side the box I just bought is thicker than it (I would guess 14 or 12)
Would this cause performance issues?
pic related
side note: any suggestions on what to set the setting to my amp would be appreciated
Uploaded with ImageShack.us
i suck men dry...email me for details
wait you have 16 gauge as power wire from a distribution block wtih 8 gauge in?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
8g for 3 amps? not! step up to og preferably, 4g min or 3 runs of 8g one to each amp. your speaker wire is fine. what amp you need help adjusting? (sub,highs?)
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
8awg for amp - 17ft 500w RMS
16aawg for amp to box (looks like 14 or 12 awg from box to sub)
I know I can't use 8awg for 3 amps...I'm wondering if 8awg is ok for 500w RMS
amp is for one sub.
rf p500-2
if its true 8g and not the small stuff they sell these days thats really 10g at best. then you should be fine. whats the biggest wire you can put in that rockford? 4?
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
For any amp, always use the largest power and ground wire that it will accept. As for speaker wire for your dash and door speakers, 16awg is fine. For your sub I would use 14
  • Who's Online   1 Member, 0 Anonymous, 4332 Guests (See full list)
