voltage drop
Alright so i have a jeep cherokee with a 220 amp high output alt from iraggi. I also have a 1800 kinetik bat up front. I also have done the BIG 3 but more like body grounds not frame. (could that be it) I DO NOT have any other batts in at this time. But im running a aq 2200d at 2 ohms and when i idle my voltage drops. Is this because i have no other batts?
I'm assuming your alt puts out around 135 amps at idle. Around 50 of the amps are used for the car itself. That leave you with about 85 amps (850 watts rms at 14.4 volts). If gains are set correctly, you'll be asking for about 1700watts (because of efficiency). Adding another battery could help.
Edit: grammar
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
There is a few tests you can do to find out what is going on. And a few things I need to know to help you out.
You have any drop when you rev it or hold the throttle at 2k rpm?
What are you playing when it drops? Try playing a sin wave at your boxes peak frequency. See what your drop looks like then.
Where is the amp grounded and what size wire you running to the amp? What size fuses you using? Is your drop at the alt, battery or amp? Or all of the above?
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
I do not have much drop at all when i rev it at 2k. Mainly when it drops is when a high note hits.
I am not familiar with sin waves. Have never done one. The amp is grounded underneath the carpet in the rear hatch area (body). Everything in the jeep is rockford 1/0 guage. 1 100 amp fuse.
I kinda live in a bad area so i never blast around my house witch means i havent clamped anything while is playing.
But will be the first thing after work tomarow.
How long is the ground on the amp? How are all of your setting? Does the clip light start to blink on the aq gain knob when you get this drop?
A sin wave is what us spl guys use when we burp our subs for max db, it is one continuous note that doesn't change you can find out alot about your electrical when you play sin waves.
Evo X build log
Id say its no longer then 3 feet. well my gain is over half. subsonic in the center. bass boost is same as the gain. And yes the clipping light does appear often. The reason i turn it up and the light comes on is because its so quit for a 2200d fi BTL 18.
Well for starters, can you make that ground less then a 18 inches long? Try rolling the bass boost all the way off and it should sound about the same and not have the drop issues.
Evo X build log
alright ill do that first thing tomarow morning. thanks for your help. still learning ha. Time for another question?
Try that and get back to me. LOL
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 1494 Guests (See full list)
