xtremeacoustiks Posted October 30, 2010 Report Share Posted October 30, 2010 would like some help with design of a 4th order, have never done any of them before.... wanna do 8 12" Audiopipe TXX-APX12W's on (2) AP30001D's...have all the equipment just need help with box design outside demensions are....40" wide X 36" Tall X 30" deep www.bassproducers.com TEAMS TEAM BASSPRODUCERS, TEAM HERTZ (VA) *Ranger System* (4) 18" Kicker Comp (4) 10" Kicker Comp Dual Stinger Alts. (5) Rockford Punch 200's (2) Punch 100's *Outlander System*152.6 DB so Far* ( TXX-APX12W (2) AP-30001D'S (2) AP-2004'S ( APMB6'S (4) KHC2400'S Link to comment Share on other sites More sharing options...
HHR Ed Posted October 30, 2010 Report Share Posted October 30, 2010 What is your goal? If going for SPL #s, you may need more airspace. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion Link to comment Share on other sites More sharing options...
xtremeacoustiks Posted October 30, 2010 Author Report Share Posted October 30, 2010 What is your goal? If going for SPL #s, you may need more airspace. I will be competing with it some..but would like it tuned around 33HZ....i competed with the same subs this year in meca but i used a sealed wall and highest score I got was 152.6 on the TL...i just wanna try somethin a little different www.bassproducers.com TEAMS TEAM BASSPRODUCERS, TEAM HERTZ (VA) *Ranger System* (4) 18" Kicker Comp (4) 10" Kicker Comp Dual Stinger Alts. (5) Rockford Punch 200's (2) Punch 100's *Outlander System*152.6 DB so Far* ( TXX-APX12W (2) AP-30001D'S (2) AP-2004'S ( APMB6'S (4) KHC2400'S Link to comment Share on other sites More sharing options...
HHR Ed Posted October 30, 2010 Report Share Posted October 30, 2010 I will be competing with it some..but would like it tuned around 33HZ....i competed with the same subs this year in meca but i used a sealed wall and highest score I got was 152.6 on the TL...i just wanna try somethin a little different Bandpass tuning isnt as simple as just stating a frequency such as 33hz. You tune an F3 down point and and F3 high point. This is the low frequency of where it drops 3dB below the peak, and the high frequency where it drops 3dB below the peak. Thats why it is a "Band Pass" it filters out highs and lows. Once you have your F3 points, you can plot the frequency curve and find your peak or peaks since there can be 2, and see if it is plotted flat. Flat is usually the best for SQ, a sharp peak is good for SPL but has a steep roll off. If you want to peak at 33hz, you need an F3 at 25hz or under, this is very low and the response over 40hz will suffer. I believe it will be best to try and get it flat from 35hz to maybe 50hz and have a slow roll off on either end. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion Link to comment Share on other sites More sharing options...
xtremeacoustiks Posted October 30, 2010 Author Report Share Posted October 30, 2010 Bandpass tuning isnt as simple as just stating a frequency such as 33hz. You tune an F3 down point and and F3 high point. This is the low frequency of where it drops 3dB below the peak, and the high frequency where it drops 3dB below the peak. Thats why it is a "Band Pass" it filters out highs and lows. Once you have your F3 points, you can plot the frequency curve and find your peak or peaks since there can be 2, and see if it is plotted flat. Flat is usually the best for SQ, a sharp peak is good for SPL but has a steep roll off. If you want to peak at 33hz, you need an F3 at 25hz or under, this is very low and the response over 40hz will suffer. I believe it will be best to try and get it flat from 35hz to maybe 50hz and have a slow roll off on either end. ok sweet...like i said ive never messed with the bandpass design before..sorta somethin i was wantin to try out....any help is greatly appreciated www.bassproducers.com TEAMS TEAM BASSPRODUCERS, TEAM HERTZ (VA) *Ranger System* (4) 18" Kicker Comp (4) 10" Kicker Comp Dual Stinger Alts. (5) Rockford Punch 200's (2) Punch 100's *Outlander System*152.6 DB so Far* ( TXX-APX12W (2) AP-30001D'S (2) AP-2004'S ( APMB6'S (4) KHC2400'S Link to comment Share on other sites More sharing options...
