HELP PLEASE!! WOOFER TO DECK NO AMP
Hey if anyone can help me I have a woofer that i want to run to a aftermarket JVC deck I do not have an amplifier the woofer is only like 150 watt peak 50 rms How do you wire a woofer to a deck? I have seen it done but have no idea how to do it please help!
134db
why? you would still need a crossover unless you are only going to play notes 100hz and below.
You'd probably only get like 25-30 watts RMS out of the deck if you could bridge it. But decks aren't bridgeable so you will get probably 12-20 watts RMS on one channel. You'd also need a crossover, but hey, it can work.
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
what is the resistance of the coil? you might be able to cross it over and use each rear channel to a coil. Why would you want to do this though? Even just a crappy flea market amp and a $20 wiring kit would be much better
Orion 2500D, Jbl Gto 75.4
Team Wolfpack Audio FSQ 15" d2, mb quart xover, tweets peerless 6.5 mids
Alpine cda-105
optima up front Knu klm 1/0
  • Who's Online   0 Members, 1 Anonymous, 474 Guests (See full list)
