DC Sound Lab
CJs DC Build Log (Subs installed last pg)
Ok got a good start on the 4 XL 18 box tonight
Box Specs
49wide x 48deep x 26.75tall
27.55ft3 before displacements
22.25ft3 after displacements
port is 8x46x16 tuned to 35.25hz. This works out to 16.55in2 per ft3 and a total of 368in2.
I would have preferred to be able to build the box a little bigger to get 6ft3 per sub but this is the biggest box I can fit under the window line.
Box is double ply and the top is going to be triple ply with the 3rd layer serving as an inset.
Sorry I didnt get alot of pics, but working by myself I forget to take assembly pics. I will get more tomorrow once i get it finished.
The 2 lips that are left on the box in the pics, the smaller one gets a second layer of mdf and the bigger one gets trimmed flush with the sides. I accidentally cut the front and back 3" to tall. I guess its better to cut it too big than too small though.
thats a big ass box cj what kinda power you running to the xls
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
nice plans & box so far cj.
is this subs & port up?
DC FTMFW!!! :popcorn:
Yep subs and port are up. I have already run into a small issue in getting 2 18s to fit between the back and port walls. It is going to be a very tight fit, but it will work. I would have liked to make the box about 3 inches longer but this is as big as I can fit in the van. He is already taking out both rows of back seats. The one thing yall dont see is a battery box that I will be building that goes on the front of the box for 3 kinetik 3800s and will also be used as an amp rack.
for right now he is going to be running 2 soundstream 3400s. 1 to each pair. I know this isnt enough power for the XLs, but I wanted to leave room to add more power later. Those amps are rated to put out 3400w at .5 ohm, so I am going to try and wire as low as I possibly can to allow for box rise and get as much power out of them as I possibly can. In the future I think he will want to add 2 more amps to properly power the subs, that is why I am doing XLs instead of 4s.
box may be a lil big for that much power, looks great though i did 2 xls sub an port up and it pounded hard. imo sub up port back is way louder though . im posted
Edited by dc98hoe
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
I disagree. Thats only 1700 per if he gets rated power from the amps, not even mentioning rise. 5.5 - 6.5 per woofer is golden IMO.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
  • Who's Online   0 Members, 0 Anonymous, 1429 Guests (See full list)
