got these boxes made after about 3 tries, a WONDERFUL story behind why but i think i will keep that between me and Bobbarker lol
more to come i dont know about the 7" driver yet might switch to the 8" we will see once in car
you using these as mids?
Working on my 93' Ford Bronco rebuild:
I have:
pioneer AVH-P6500
Infinity Reference 6032SI fronts
Infinity Reference 6832CF Rears
Crescendo CZ 6.5 kicks
Crescendo 1100.4
(2) DC Audio LvL 4 M2's
(1) Juicebox Blackcherry
Piece together amps & wiring
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
Sky High Car Audio Wire
Rockford Fosgate 360.2 or .3
My Build
http://www.stevemeadedesigns.com/board/topic/97426-93-ford-bronco-rebuild-full-system-body-paint/
yes those are for the mids, im kind of sceptical about the size dont know if it will sound the way i want so might get an 8" instead of a 7" but we will see once in car, i got stranded at someones house car is there do to weather, only have summer tires on car. >.<
oh ok kool...
summer tires??????? You know better, you live in michigan. sunny & 90 one day then -10 below with 8' snow the next!
get some all weathers next time (unless you street racing) :lol:
I have:
pioneer AVH-P6500
Crescendo 1100.4
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
My Build
This was origanally a summer car but my winter car's turbo blew so uhg
ooooooooooooooooooh ok.
I have:
pioneer AVH-P6500
Crescendo 1100.4
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
My Build
got the midbass boxes screwed and secured into the car and playing, most likely will be changing the 7" to 8" midbass drivers but DAMN do i need a bigger car
will be redoing the covering when i swap out the 7" for the 8" but i got no room in the back HAHA
nice...
I have:
pioneer AVH-P6500
Crescendo 1100.4
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
My Build
well i did alot of work today and they still need to be painted but i got the pass. side door pod in and playing and WOW it sounds AMAZING !!! i cant wait to get the other side done will be doing that tomorrow
also need to get a new set for the top woofer as the center has been messed up and i like the newer model of the speakers i have, much better construction!
  • 3 weeks later...
ok update on the car, some audio some not
this was from 3 diff post on a diff forum thats why it seams spaced out
got some work done finally now the the weather is barely tolerable....
using 2x 10" slim fans pushing, car sat at idle for a long time and held a steady temp so all things work, also got the dual stage boost controller hooked up and i love it!
ok so i did some more work to the car today, some little things but they make a difernece, first i fixed my windsheild wiper motor so now my wiper blades dont stop mid eye sight, what a relief, then i changed my tstat and here are before and after pics for Rocketman
before after driving for about 30 minutes
after, after driving for 30 minutes, now my car runs a little better and seems to be running more lean at idle/cruise maybe ill have better fuel now HAHA
i got around to also doing my rear speakers there now in i dont have a pic of the speakers in but i will soon, here is a comparison of the door speakers and the rear speakers
rear(right) is an 8" midbass woofer door speaker (left) is a 7" midrange speaker
i also am working on getting rid of my hood rattle and cleaning her up a bit with some sound deadner ( good up to 500 degrees ambient heat)
also painting the hood clip (or what ever its called)
paint is 500 degree engine enamal then will coat with a clear lacquer so it should be able to hold up to the use of the latch.
ok got the hood done and HOLY #@$! it sounds like a brand new car!!! i used silicon for the seams, sound deadner for the hood area and then filled the braces with exspading foam, it added probably 2 lbs to he hood so it doesnt make a difference in weight but it sounds AMAZING !!!
and here a vid
also i got a chance to take a picture of my wire up front
thats 0AWG welding wire one goes to the back where the battery is the other is connected to the alternator and then the third wire goes to the second distributor block
both blocks and the wire
thats 0AWG from the other block and 2 4AWG wire one goes to the fuse panel and the other goes to the starter, everything is welded and heat shrunk for best results, i dont have a picture of the grounds but on the Passenger side i have a 0AWG ground from strut mount to engine block and on driver side i have a 2/0 AWG wire going from frame to tranny case.
