Thank You!
POINT AND CASE, Slim!
2009 VW Rabbit 2-Door:
Pioneer AVH-X1600DVD
Kicker CX600.1 (Kicker "Certified" 638wrms@2ohm)
NVX VCW124 @2 Ohm, ~1.25 ft^3 Sealed box
Stock Doors; (4) 6.5's, (2) 4's, (4) 1" Tweets
Owner/Founder of RT Photography
Canon Traitor who moved to Fujifilm
I say it would be much better to build your own since you are already going through a hassle trying to modify a prefab box. give yourself some decent port area, and a nice low tuning, and you are golden my friend.
My System:
Pioneer AVH-P3200BT
4-Dayton 7 inch reference series (front doors)
8-Onkyo 3/4 inch tweeters (dash)
1-Sundown Audio 100.4D (mids/highs)
2-18" BTL's (for now)
Crescendo 3kwp (for sale)
Complete rebuild coming soon...
only thing I can see what would be wrong about it is, if its a pre -fab box, with the woofers that came in the box, that the tunning is set for a reason, because its optimized for that tunning with that air space, with that woofer...
if its a generic box, and maybe the woofer requirs small ported, low tuned, then why not?
I know I have done it a few times at shops Ive worked at, get yourself a prefab sealed box, a 4" port, cut the hole, wedge the port in place test, and cut port to length as needed to compensate for tuning, start off with a calculated length, with a the lowest possible tuning, and every inch or so you cut, your raising tuning about 1-5hz depending on air space
The box doesnt have the orig equip in it... It was running 2x JL 12w3... Now it runs 2x Kenwood W3011's Ill get the specs in a few....
Audiobahnaholic, how did you finally get the extra 10.5"? From the center or from the edge? I read the whole thread, and need more answers...
Thank You!
Ok Mr. 40hz! The way you described to me was as if you were going to just add a small sheet of wood directly into the port, and thats it! Since I haven't actually seen the inside the port I don't know how much room you have to turn it into a L shaped port. Thats why I said that idea wouldn't work! I still think your a Dumbass :D !
1998 Toyota Camry XLE V6Goldwood GW-S650/4 6.5sEA 200a alt2009 Lancer GTSStock jtte2o.gif
Man, thats low... lower than 40Hz :D
I mean, there's no real reason why this cant work....
