ok started to fab the blow-through today with a flat-lay down method of fiber-glassin' the mold that will attach to the rear deck to make a one piece back panel , blow - through.
Had to remove the rear seat , again !!
Then started with the Glassin' !!!
the result, i will trim it all up after it cures well and post some more pics later !!
Build continues, test fitted rear deck panel and i am going to have to recess the 8's down through the panel to get them ant the tweets to fit. Surprisingly there is very little room in my rear deck !!
The Tweets and resistors came in today so i can start fab'ing those up also !!
Test fit of the rear deck, i will be recessing the 8's on each side of the third brake light hump, and then the tweets on the outer sides;
More pics tomorrow !!
This is pretty awesome. Did you learn most of the build aspects from SMD?
I frequent a few different sites but , YES i learned a lot from these forums especially SMD !! Thanks for the compliment , i stay on a very strict budget so i have to do a lot of surfing and research to find the best and cheapest way to do things and a lot of it is trial and error also, especially when you are trying to do it CHEAP !!!!
ok , here is what ive got done so far but this time i need some of you guys input on what to do because i have come up to some road blocks and im kinda losing motivation and i need help !!! I have very little room in the rear deck, a lot less than first thought. I can fit the 8's and the pro tweets only if i take and recess the 8's down into the rear panel, this isnt such a big deal but it will require more work underneath to keep them separated from the trunk because of cancellation problems from the subs.
So i need yall's help bad !!! Should i go ahead with the 8's, the center blow-through and the pro tweets , or should i just forget the 8's all together and just mount the pro tweets in that spot and do the blow-through ??
Very hard to get everything centered and even on both sides !!
The one thing that i know that has to be done is the Blow -through !!
This is one of my favorite builds! Dont give up man! :D
I really appreciate that dude , i think im goin to go for it and stick with the 8's and the tweets with the blow-through !!
Do it! :whip:
Check out my build log!
