Winn Posted November 6, 2010 Report Posted November 6, 2010 Can just regualar 6 gauge wires be used as power and ground because i have rolls of them and other gauges. also what gauge speaker wire should i use for my sub? Which is a P3 Shallow 10 300 watts rms. Also can i use just random wires as speaker wires? just wondering Winn You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back. JUST SAY ANTI-AUDIOPIPE
Jbabycsx Posted November 6, 2010 Report Posted November 6, 2010 I dont think you can go wrong with using the biggest wire your amp will accept. If it will accept 0 gauge, use 0 gauge, if not use the biggest wire you can. As far as that sub goes, using 12 or 14 or even 16 gauge should be ok. 2000 GMC Sonoma AQ20 FTMFW! 4 DC XL 15's Cadence ZRS-C9 Infiniti Kappa 3.5's and 6x8's Bravox 6.5 components
bumonskateboard6 Posted November 6, 2010 Report Posted November 6, 2010 You could do 12 gauge for the speaker wire, but on any amp I never go smaller than 4 gauge for power/ground, I have a 300 watt rms fosgate amp that I still power with 4 gauge, and the rest is 0 gauge. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
Guest Posted November 6, 2010 Report Posted November 6, 2010 my rule of thumb for power/ground. always use the biggest wire the amp will accept. for speaker wire, 14-16 gauge will be fine for mids and highs, for subwoofers i would use 12-14 (for mid to low power)
