I can prolly invert subs help with cooling right.how do you figure the amp at .5ohm to rise only 1500 watts
It's a zenon board. Unless you have little to no impedance rise, then I'm willing to bet you'll clamp 1500 watts rms outta it.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
If its inside they will.
If the inside is 8"s you would have 9.5 on the outside. Subs mount in the outside ...
what you ,ean outside 9.5 see this is why I want a better drawn up design.I like this one and want this one but would like a google sketchup with measurements
Inside where the subs mount I'm assuming is gonna be 8"s.
The place where the subs will mount to ( baffles as called above ) on the outside of it, will be 9.5"s after the double baffle.
Because 8 + 1.5 = 9.5 or did math suddenly change?
If an XL takes 8.25" to mount .. 9.5 - 8.25 = 1.25 ...
So there would be 1.25"s foam mags to back wall...
I think you are part of the group we refer to as "the factor"
:P
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
:P
no I understand that its states on the design not to dble the port so theres only .75 for the port walls so would it still fit then
Why wouldn't it still fit? Look at the design again and tell me why it matters how thick the port is. The space the subs have to mount in the sealed chamber have nothing to do with how thick the port is
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
so you think its a ok design then should I build it or what
With the questions you've asked so far, I don't think YOU should build it, but someone should.
But yea i think it's a decent design, but, I would tweak it to what ive been taught on bandpass
Edited by dwright27
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
