Question about switching amps
SLOPALA
I currently have 2 12" Eclipse SW8122.4 (4ohm) with an Eclipse DA6213 amp pushing 250 watts (4ohm) to each sub. The Subs are rated at 500 W RMS. I would like to eventually run a Rockford Fosgate T2500-1bd. The amp is rated at 1000 watts X 1 ch. @ 4 ohms. How would I wire my 2 subs to a 1 channel amp?
HU: Eclipse 8443
Front: Eclipse SC8362
Rear: Eclipse Point Source SP6900
Subs: Eclipse SW8122.4
Amps: Eclipse PA5422 & Eclipse 34230
EQ: Audiocontrol DQS
is that sub dvc? then wire each in series to 8 ohm and just wire them normally to amp and the amp is connected internally so it will bridge it down to 4 ohm anyway.
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
Sorry they are Single Voice coil. So, I would have to wire the subs parallel?
HU: Eclipse 8443
Wire them at 2 ohms and find an amp that does 1000wrms at 2 ohms... A T2500 is more of a 3000wrms amp and wouldn't be beneficial unless you wanted to upgrade subs and electrical.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
How would I go by wiring a 4 ohm dual sub set up to 2 ohm. (sorry for the noob ?)
HU: Eclipse 8443
  • Who's Online   0 Members, 0 Anonymous, 1278 Guests (See full list)
