depends on your box.....
I would say a flared slot port,
If you just want that range alone i would do something like 16 to 24 sq inches of port per cube, depending on the subs tuned around 20~23hz
but that would most likely suck on anything above 35~40hz
if you want something that is musical that will still go down that low it would say again a flared slot port
tuned to 30~33hz with 10~12 sq inches of port per cube
15s? what kind?
well with 13 cubes after disp. if you go with 16 sq inches of port at 23 hz your port is gonna be 70 inches long and almost 9 cubic feet.
if you do 24 sq inches per cube at 23 hz youll be at 110 inches long and about 20 cubes.
both of those will most likely not fit and only be good in that range you said.
but for more musical
12 sq inches at 33 hz, youll have a 24 inch port only taking up a 2.16 cubes
Since you have Kicker squares 12's, design the box like it was for 15's since that is about the cone area you have, You need alot of port area for 4 and it would need to be pretty long, don't do aero's so one big ass slot port. Just use a slot port calculator, there is one on this site and 12volt has one too. But it is gonna need to be long, I can tell you that. Give me your exact dimensions and I can figure it for you if you are lazy. 8)
Edited by AMI CUSTOMS
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
naw... im not lazy i use Torres box tuning calc
15s? what kind?
Alright i was looking at my box calculator and what i said before was wrong. i forgot that i added the port to the over all disp. here is the real specs
outer specs w/o bracing
H = 21
W = 50
L = 26
1" wood
I can go up to 32" long if i wanted
Edited by thafreek
Well i did a 4th order bandpass to crush those tunings. I tuned my at 33hz 5.5 cubes ported and 1 cube sealed for my 15, and it crushes the lows from 35-21, its the hardest from 26-30, really feel the pressure change at 28hz. Its a diamond audio d3 15, in my room on 250 rms.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
i had my kickers in my room and they didnt sound as good as they did in my truck
