did you run a sinewave and see where your peaking at? frequency mite have changed with box design
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
funny how systems are loud to the ear but don't do high termlab numbers more experimenting needed do you want to just do numbers or sound good on the street cause You might want to take one 8 out and put it in a sealed box and burp it to try and find the peak frequency of the truck unless you already know it then build the box ported to the peak freq of the truck
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
I was wanting to do #'s for comp. coming up. how big of a sealed box? it's just for testing right so doesn't need to be like an optimum size or anything i'm guessing
Team Flex Issues
