okay so i can already tell my highs wont keep up with my subs.. i have 2 5x7s in front doors and 2 6x9s in rear deck. dunno the rms on them. oem tho. (02 sebring) and i just put in a kenwood 25th deck hoping it would make them louder but its around the same. i ahve 2 jl zr tweets that are about 50-60rms single 4's. im thinking of getting another set of some tweets (might not be the same) but around that same rms and impedence. i have enough mid bass trust me lol but basically im planning on running 4 tweets, what are some good amps you would recommend? im really a mids and highs noob.. i dont really know squat about 4 channels either sorry :noob: i would prefer sundown to match my saz1500 but that shits pricy lol
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
SD does have 4 channel amps...
i know they do... shits pricy tho lol basically im looking for a good cheap 50x4? if thats right? but dont mind much power lol ill leave 5x7s and 6x9s running off deck and add the tweets off amp.. would that work?
Well do you still want everything to be stereo? Like front to back and right to left all being seperated? Or does that not matter? Because you could run the 4 speakers off 2 of the channels and the tweets off the other 2. Just powering the tweets wouldn't add any vocal.
Unless the tweets have crossovers, then you could/should power all 6 drivers on a full range crossover.
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
Hifonics 55.4. Im running 2 5 1/4 in the door, 2 6x9 in back, and they keep up with my sub just fine.
2006 Nissan Z Track.
My Feedback Thread
uh i would seperate the tweets, left door panel right door panel, or put them in center.. idk i thoought adding the tweets with power would add vocal?? the tweets do have cross overs on them.
could you explain that to me a little better? dont want to swap out my door speakers.. i like how my stock ones hit lol
and pyle amp....? :shrug: ? pm me with info bro ill see whats up, and about the audioque not looking to spend that much :( 120 under lol
Umm on an active crossover, the low pass high pass and full button on almost every amplifier, you would wire lets say a 4 inch full range speaker and a tweeter with a passive crossover (that little cylindrical thing on the tweeter most of the time) then the full range 4 inch would play all frequencies and the tweeter will only play the frequencies that its crossover lets it.
Tweeters do not add vocal, they add much higher frequencies like for cymbals and the stuff that literally hurts your ears.
Tercel build R.I.P.
V-Dub
My feedback.
