I have a strange voltage problem. When I pull up at a stop light playing music with about 1/4 volume my voltage sometimes reads about 11.9 volts at my 4 channel amp. When I hit the highway it goes up to about 13.5 volts, which I would expect, but what I don't understand is when I put my car in park and let it idle the voltage goes up to 13.5 and I can go full tilt and it only drops to about 13.4. I don't really understand how idling at a stop light is different than idling with my car in park. Hopefully someone can help me understand why this is happening. By the way my equipment is listed in my signature.
Thanks,
Jake
Car
1991 Honda Accord EX
System I now have and is finally installed!
Pioneer DEH-P7200HD
Digital Designs 3512
Digtal Designs CS 6.5" components
Audioque 2200
DD Audio C5b
Optima Yellow Top
Rockford Fosgate 1/0
Damplifier Pro
Luxury Liner Pro
the only thing i can think of is that if you have an automatic the load on the engine will make it rev a few hundred rpm lower if it is in gear than if it is out of gear, that extra little bit may be enough to keep your voltage up while in park
Orion 2500D, Jbl Gto 75.4
Team Wolfpack Audio FSQ 15" d2, mb quart xover, tweets peerless 6.5 mids
Alpine cda-105
optima up front Knu klm 1/0
my car idles about 300rpm lower when in drive or reverse as opposed to park or neutral.
i have voltage fluctuations like that also when changing from drive to park. it all matters on how fast the alternator is spinning.
What's your voltage with your car off no volume. Also what's your voltage in park, drive and neutral?
This I am not completely sure of since my voltmeter only comes on when the head unit turns on. Also currently I can't access a DMM to test it.
What vehicle Is it?
1991 Honda Accord.
Car
Pioneer DEH-P7200HD
Audioque 2200
DD Audio C5b
Optima Yellow Top
Damplifier Pro
Luxury Liner Pro
Aftermarket alternator?
No, stock alt. Saving up for aftermarket one.
Car
Pioneer DEH-P7200HD
Audioque 2200
DD Audio C5b
Optima Yellow Top
Damplifier Pro
Luxury Liner Pro
i am going to go out on a limb here and say something is malfunctioning inside your alternator. my stock alt worked fine until one day, not sure what happened, it was just different. i popped the hood to find smoke rising, thought my alt was shot. at idle it would sit 12, sometimes dropping down to 11.9 if i had anything running (stereo, lights, heater, etc). but when driving around it would sit 13.6 or even 13.9 sometimes. i would look into getting a new alt before anything gets ruined, because it sounds like it isnt working properly
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
  • Who's Online   0 Members, 0 Anonymous, 911 Guests (See full list)
