Eclipse 8454 RF750X Concept1200d
Ive got some stuff up for sale again. Its just sitting in the basement now so why not
First up Eclipse 8454 head unit
this is true eclipse 8volt preouts.time alignment you name it. One of the ultimate SQ head units thats affordable. some where on the one scroll wheel but other than that in great shape. includes trim ring cage harness etc.
165 shipped
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Next up is an RF Power 750X. It has the red led on the top in case someone was looking for the blue version. This is a tank.
Details:
* 90 watts RMS x 4 at 4 ohms
* 187.5 watts RMS x 4 at 2 ohms
* 375 RMS watts x 2 at 4 ohms in bridged mode
* amplifier requires one 60-amp fuse (not supplied)
* 2-, 3-, or 4-channel output
* Tri-way capable (Tri-Way crossover required)
* MOSFET power supply and output devices
* front and rear 50-250 Hz high-pass/low-pass crossovers, 24 dB/octave slopes
* requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
* dimensions: 18-7/16"W (14-13/16" without endcaps) x 2-7/16"H x 9-7/8"D
this did birthsheet at around 110 watts per channel at 4 ohm
and 200 per channel at 2 ohms.
there are a couple scratches on the end cap and the remote lead has a piece of remote turn on lead on it already. was a little worried about pulling it off and pulling hte whole terminal off. You can just splice into your lead
one end cap is missing hte set screw. This does include the bass knob.
130 shipped
this thing is super dusty ill try to clean it up an get better pics up in a little
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Concept 1200d
1200 watts at 1 ohm.
solid little amp and fairly clean. It will do rated.
120 shipped
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i had a deck like that b4 and liked it. if its still 4 sale in feb i'll get it and if i remember thats a dry deck as in needs a amp 4 sound
Team DBs (Driven By sound)
it has an internal amp. If you buy this to not use it with the preouts though you are a dipshit.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
so im in the mood to post dump....great guy here ships faster then a hooker uses her mouth :)
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
wuts with name callen dude? the one i had didnt have a internal amp
Whats with the lack of reading comprehension? I said if you buy this and use the internal amp you are a dipshit. It has 8 volt preouts for a reason. I never once said hey corteznewbie you're a dipshit.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
bump to the top. my prices are flexible somewhat.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
