here is the wiring diagram just incase u need it
2006 Dodge Dakota Car Stereo Wiring Guide
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located in the passenger kick panel.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Dark Green/Brown
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Brown
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Dark Green/Dark Blue
Left Rear Speaker Negative Wire (-): Dark Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Dark Blue
Right Rear Speaker Negative Wire (-): Gray/Orange
and try to carefully pry with a flat head screw driver between the highlighted areas that whole cover should come off along with the AC vents start from the corners or edges
Alright when I get the dash kit will try that! Thanks!
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
