Alright,I'm almost convinced that this is impossible to do but i want to see what you guys can help me with this.
My dimensions are H 13.75 W 30 D 24
For two SA 12's which are 1.75 cu feet each displacement of .3 for both the subs and i need it tuned to about 33hz... please include a sketchup because i can enter dimensions but it wont fit.
how does this look. I would fire the port and the subs facing the front of the car because i cut a big hole behind the middle arm rest and the port would fire right there. 5177291488_067452e2b4_b.jpg
also my question is its a little below 3.5 my current box is 3.5 but im getting port noise and will it be audible? i plan on upgrading to a aq2200d sometime.
Port noise comes from hard corners inside the box and a small port area.
With that setup you will have tons of port area. See where is says "port area range"? Right above "port area" on the right. Try to stay on the larger side of that range for least port noise.
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
