BassHead1990 Posted November 15, 2010 Report Posted November 15, 2010 I went to look at my dad's wiring setup because they the HU wouldn't shut off when the car was shut off and come to find out that there is no postive signal from the ign wire. His Ignition is kinda messed up, the switch rotates all the way around backwards but the car will start fine when turned forward and shut off like normal so it obviously works. Could the wire have a short from the ign to the HU or is the ign switch F'ed up and need to be replaced in order to get a signal. Idk if taking off the faceplate actually does anything since the ign wire was hooked up at the constant. "seems" like an easy troubleshoot, but always good to hear what you guys have to say. (2007 Chevy Tahoe LT) Mechman 320A OEM AGM D'Amore Engineering HLC-2 Sig Converter D'Amore Engineering E1500.1 Fi Audio Neo 3.5 12"
dwright27 Posted November 15, 2010 Report Posted November 15, 2010 Well, that should cause him to lose his settings everytime he starts the car as well which is a pain in the ass. Get up under the dash and find a new ignition wire. Tap it and run it to the radio. 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
