Carroot1 Posted November 16, 2010 Report Posted November 16, 2010 Since im rebuilding my box, im wondering about aero ports. Subs 2 SA 12s Amp AQ1200D 4 gauge My Box Specs are W 30 H 14 D 24 Is there anything i should know about aero ports like how far they should be away from a wall Idk this might be my best bet. 2 5inch aeros tuned to 35hz with 11 cu feet of port puts me in good port range. Any help is appreciated Thanks! Quote
bobonit Posted November 16, 2010 Report Posted November 16, 2010 Since im rebuilding my box, im wondering about aero ports. Subs 2 SA 12s Amp AQ1200D 4 gauge My Box Specs are W 30 H 14 D 24 Is there anything i should know about aero ports like how far they should be away from a wall Idk this might be my best bet. 2 5inch aeros tuned to 35hz with 11 cu feet of port puts me in good port range. Any help is appreciated Thanks! They don't make 5" Aeros, they have 4" and 6" though. Try to keep them the diameter of the port away from the wall. So if its a 6" port, keep it 6" away from the wall. Quote 97 Maxima SE Bunch of shit going in, check out the build Build Log
Carroot1 Posted November 16, 2010 Author Report Posted November 16, 2010 will i be ale to fit 3 4 inch aero ports on the front of the box thats 14 inches tall because its tuned perfectly. 30 wide 14 high 22 deep 3 4 inch aeros that are 18in long tuned to 35hz Quote
anubis Posted November 16, 2010 Report Posted November 16, 2010 and you mean 11 squares inches per cubic foot which is good Quote 1998 Monte Carlo Z34 Stock HU but have replacement Stock Highs Stock Electrical BTL 18 sitting naked AP1500D
Carroot1 Posted November 16, 2010 Author Report Posted November 16, 2010 where can i buy 4 inch aero ports that are 18 long? Quote
bobonit Posted November 16, 2010 Report Posted November 16, 2010 (edited) will i be ale to fit 3 4 inch aero ports on the front of the box thats 14 inches tall because its tuned perfectly. 30 wide 14 high 22 deep 3 4 inch aeros that are 18in long tuned to 35hz Just remember that the tubes will be 4", the flares will be larger. I'm not exactly sure how wide the 4" flares are, but the flares for my 6" aeros are 9" wide if that gives you an idea. Edit: I found this on the Precision Port website... Can be used in any type of ported enclosure as long as you have left a minimum diameter of 5.25" for 2" ports, 6.25" for 3" ports, 7.25" for 4" ports, and 9.25" for 6" ports. Edited November 16, 2010 by bobonit Quote 97 Maxima SE Bunch of shit going in, check out the build Build Log
herbykw Posted November 16, 2010 Report Posted November 16, 2010 (edited) will i be ale to fit 3 4 inch aero ports on the front of the box thats 14 inches tall because its tuned perfectly. 30 wide 14 high 22 deep 3 4 inch aeros that are 18in long tuned to 35hz edit.. already answer took too long to type Edited November 16, 2010 by herbykw Quote 06 300C 5.7 Hemi K&N CAI JVC KW-AVX640 6.1" DVD DC Audio 3.5k 6 DC Audio 8"s 6 cubes 8" aero port at 32hrtz http://www.stevemeadedesigns.com/board/topic/183798-chrysler-300c-8-build/?p=2731834#entry2731834
skittlesRgood Posted November 16, 2010 Report Posted November 16, 2010 (edited) where does the 11 cubic feet in the port come from?? box looks like itll be about 4.5cubes? two 6" ports will give you 56.5 square inches of port area so its about 12.5 per cubic foot. that should work very well. exept you'll never get down to 35hz. full length of those ports are 17" and itll give you a tuning around 39-40hz. just going off memory here. my box is JUST like what you are trying to do. might want to check out my build log. only difference is mine is a little shorter but wider. also make sure there is at least 5" from the front of the port to any hatch. edit - shit, i guess i type slow at work. Edited November 16, 2010 by skittlesRgood Quote If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
