Since im rebuilding my box, im wondering about aero ports.
Subs 2 SA 12s
Amp AQ1200D 4 gauge
My Box Specs are W 30 H 14 D 24
Is there anything i should know about aero ports like how far they should be away from a wall
Idk this might be my best bet. 2 5inch aeros tuned to 35hz with 11 cu feet of port puts me in good port range.
Any help is appreciated
Thanks! :drinks:
Subs 2 SA 12s
Amp AQ1200D 4 gauge
Thanks! :drinks:
They don't make 5" Aeros, they have 4" and 6" though. Try to keep them the diameter of the port away from the wall. So if its a 6" port, keep it 6" away from the wall.
97 Maxima SE
Bunch of shit going in, check out the build
will i be ale to fit 3 4 inch aero ports on the front of the box thats 14 inches tall because its tuned perfectly.
30 wide 14 high 22 deep
3 4 inch aeros that are 18in long tuned to 35hz
and you mean 11 squares inches per cubic foot which is good
1998 Monte Carlo Z34
Stock HU but have replacement
Stock Highs
Stock Electrical
BTL 18 sitting naked
AP1500D
Posted (edited)
Just remember that the tubes will be 4", the flares will be larger. I'm not exactly sure how wide the 4" flares are, but the flares for my 6" aeros are 9" wide if that gives you an idea.
Edit: I found this on the Precision Port website...
Can be used in any type of ported enclosure as long as you have left a minimum diameter of 5.25" for 2" ports, 6.25" for 3" ports, 7.25" for 4" ports, and 9.25" for 6" ports.
Edited by bobonit
97 Maxima SE
Posted (edited)
edit.. already answer took too long to type
Edited by herbykw
06 300C 5.7 Hemi
K&N CAI
JVC KW-AVX640 6.1" DVD
DC Audio 3.5k
6 DC Audio 8"s
6 cubes 8" aero port at 32hrtz
http://www.stevemeadedesigns.com/board/topic/183798-chrysler-300c-8-build/?p=2731834#entry2731834
Posted (edited)
where does the 11 cubic feet in the port come from??
box looks like itll be about 4.5cubes? two 6" ports will give you 56.5 square inches of port area so its about 12.5 per cubic foot. that should work very well. exept you'll never get down to 35hz. full length of those ports are 17" and itll give you a tuning around 39-40hz. just going off memory here.
my box is JUST like what you are trying to do. might want to check out my build log. only difference is mine is a little shorter but wider.
also make sure there is at least 5" from the front of the port to any hatch.
edit - shit, i guess i type slow at work.
Edited by skittlesRgood
  • Who's Online   0 Members, 1 Anonymous (See full list)
